Help for a simple patch: Convert an audio impusle into an midi trigger
jules wysocki
Unread post by jules wysocki » 28 Feb 2024, 08:46
I'm new here so I have a newby question for you.
I need to use contacts mic to trig a sampler when I hit them (Probably 2 mics so to audio input)
I know that it possible to convert this audio impulse into a midi note to play and stop a sampler.
Could you help me to find the perfect object to do that?
Many thanks for your help.
Jules.
titl
Unread post by titl » 28 Feb 2024, 15:38
You can use audio analysis peak detector or beat follower and generate a midi note on with midi generator note on use trigger input), and after filter this note etc...
Unread post by rlgsbt » 28 Feb 2024, 17:20
here is a very simple example
audio to MIDI note.wkp
(240.59 KiB) Downloaded 483 times
you can also use "Analysis Audio to MIDI 2" module if you need to get midi notes by frequencies
Users browsing this forum: No registered users and 35 guests
