Is there a way to use Usine with a bluetooth speaker (need it for an installation)?
Thank you
Bluetooth
very strait forward :
connect the bluetooth speaker to the computer, then launch Usine, select directsound and your BT speaker
may lag quite a bit....
maybe it is possible to use more than one BT speaker, but because of latency, you'll have phase issues if sending same signal on different speakers
Seb_Brun
Not sure to understand "directsound".
Do you think I can use an RME and several Bluetooth speakers (independantly) ?
Thanks.
S.
Thanks.
S.
@oli_lab: thank you for your answer, i'll try this!
- rlgsbt
If you want to use your pro sound card and its drivers (ASIO for PC), you can also use an audio receiver/transmitter, plug to your outputs
I use this one ;: https://www.amazon.fr/gp/product/B0BFH2 ... UTF8&psc=1
it's efficient but you have a big latency
- x.iso
with latest BT standards latency shouldn't be more than 10ms. and yeah, using receiver/transmitter is the only way to go if you want BT speaker to work with your audio interface. if I recall correctly, even some audio interfaces that have bluetooth built-in, only use it to connect to PC wirelessly, not speaker.
BT Speaker on it's own could be used with WASAPI driver on Windows with 10ms latency (potentially you could try going lower), but that means it's going to act as audio interface.
