I'm just using the "Image, picture" -module for the first time but as I was trying to load a file I got some distorted results. I have an image 16 pixels high, but Usine seems to stretch the image vertically. Horizontally it seems the right size. Same happens whether I bring in the same file as BMP or JPG. Any idea what's up?
antwan
About the Image, picture -module
there is a zoom factor inlet in the Image module.
Did you try it?
Did you try it?
yes it's set to 100%. Also tried other settings but it just scales the distorted image. /antony
I'll take a look to see there is bug with small images.
hi,
great, thanks. actually to be more specific: the zoom control only seems to resize it horizontally with settings 8-250. And only after approx 250 it starts to zoom also vertically.
antwan
antwan
Users browsing this forum: No registered users and 135 guests
