record Sys Ex
record Sys Ex
Unread post by Gilsornette » 10 Nov 2023, 09:02
Has anyone ever managed to record a dump SysEx (from a synth) with the SysEx Editor Module? On my side it's not working,
the editor is always reset to size 1 with no datas recorded. I tried with other Sys Ex recorder (Midi Ox, Patch M4Live) and the dump
is correct and well recorded. Thank you for your help.
Unread post by oli_lab » 11 Nov 2023, 20:30
I did some test with my Blofeld,
I reckon there is a problem with the sysex output on the midi input module :
when sending dump from the synth, I receive an empty array [0] then the dump [390], then another empty array [0]
so the sysex editor store only the last empty array !
here is a workaround :
Unread post by Gilsornette » 11 Nov 2023, 21:12
Thank you very much, that's a good advice!
