Dynamic Image Button
styro
Unread post by styro » 10 Nov 2023, 02:24
Trying out this great Software, and i am stuck with following problem:
is it possible to make a buttons look dynamic by changing the png image File with a trigger?
or how can i put a png in the "bitmap in" port of the button?
Many thanks for any help!
all the best
styro
Unread post by SylvainT » 10 Nov 2023, 11:12
Yes, it is possible.
Deploy the module, find "back bitmap" string inlet. Here, you will enter the address of your .png
If you change the address, you change the image.
styro
Unread post by styro » 10 Nov 2023, 18:07
Hi SylvainT
Thank You so much, works great!
The Quickness of the response just convince me to buy the expert version of HollyHock, looking forward working with it!
all the best
styro
