Speaking with some friends, all of them Mac (Intel) users, I found that most of them really liked Usine but when I told them "no Mac version" they completely rejected it.
I've read on the forum that a VST version of Usine is in the works, although I'm not sure I really understand what that means (that we will be able to open our favorite sequencer/DAW, arm a track and insert an Usine VST with all its routing and control possibilities?), two thoughts came to my mind:
1) What if there was a way to build platform-independent VSTs?
2) Hey! Java is supposed to be cross-platform!
Amazingly enough, I did a Google search for java and vst, and found:
jvstwrapper.sourceforge.net/
which should do exactly what it says...
What do you think? Personally, I'd switch to a Mac tomorrow if I was able to use Usine without booting into a Windows partition...
jvstwrapper: java wrapper for VST
thanks for the advice.
A cross platform version of Usine will be a hard job. Usine is a 200.000 lines of codes program: huge, I can't believe I did it myself...
I hope I'll have time to do that one day...
The java language isn't really suitable for intensive audio DSP. It's an "pseudo interpreted' code which means, slow...
Users browsing this forum: No registered users and 51 guests
