Audio select module
Ariajazz
Audio select module
Unread post by Ariajazz » 16 Oct 2023, 18:07
Hi all. I'm looking for a module that does the opposite effect of the AUDIO MIX DISPATCH module. The idea is to get different audio signals from different audio buses in the input and be able to select which one will go to only one output. It is a sort of a mixer but only selecting the audio sources. In old USINE 5 it used to be AUDIO SELECT module.
Unread post by rlgsbt » 16 Oct 2023, 21:38
You can use the "Matrix Audio" module, with mutilple audio in, but only 1 output
[attachement=0]Capture d’écran 2023-10-16 213735.jpg[/attachment]
Ariajazz
Unread post by Ariajazz » 16 Oct 2023, 23:45
Thanks for replying. Just one thing : The audio buses are stereo.
Unread post by rlgsbt » 17 Oct 2023, 07:07
"Audio Mix Matrix" module is stereo (and you can manage your stereo input buses with an array)
Unread post by oli_lab » 19 Oct 2023, 17:49
basic solution :
you can have any numbers of inputs or outputs (512 in HH6)
Unread post by rlgsbt » 19 Oct 2023, 19:34
in stereo, you can use some array like this :
1;1;0;0;0;0;0;0
0;0;1;1;0;0;0;0
0;0;0;0;1;1;0;0
0;0;0;0;0;0;1;1
or a preset manager to recall 1+2 3+4 5+6 7+8
Ariajazz
Unread post by Ariajazz » 11 Nov 2023, 14:46
Hello. Thaks all for your replies. I did find a solutios usig the SELECT module. AUDIO MATRIX module using arrays is also a great one. Unfortunately I don't know much about using array althogh I understand the example given by oli_lab. I wish I could learn more about using arrays which I know is a great tool.
Users browsing this forum: No registered users and 38 guests
