I assumed that the "array shuffle" module was randomizing data's positions only when triggering the shuffle input
but, as I'm trying to use it in a patch, it seems it shuffles as soon as datas are incoming the module. Is that right?
Array shuffle
if the size of the incoming array changes, it reshuffles the array
if the size stays the same, it does not reshuffle when values change, you'll have to push the shuffle button.
Ok, I understand. Thank you very much!
Users browsing this forum: Google [Bot] and 24 guests
