Global Remote: Shortcuts for "selected channel"?
- senso
There are short cuts
solo (shift+s)
mute (shift+m)
headphone (shift+m)
The problem is that you can't change them...
Good suggestion anyway
I will suppress thoose fixed short cuts and add a key learn in the global remote. You will be able to choose any you want!
solo (shift+s)
mute (shift+m)
headphone (shift+m)
