Redesigning two-level lists using arrays and matrix?
creal
Unread post by creal » 10 Dec 2022, 11:24
I made a patch that works fine (workspace attached), but now I would like to put the IB design one step forward.
At the moment, the user has to select an item in the first list (category), then select a second item (preset) in a list that is visible depending on his first choice.
I would like to get two columns, always visible and at the same place. The first would be at the left, the second would be at its right, but the two has to be locked in termes of positions, as if it was a table. A good example can be found on the FM8 browser (Native Instruments). Maybe it's a very common technique the field of design but I don't know the exact term.
I don't know if I can use a matrix to achieve this goal. Or other modules?
If I am not clear enough, please tell me and I will try to give more details to my request.
creal.
FP-30X programs.wkp
(456.17 KiB) Downloaded 436 times
Unread post by SylvainT » 10 Dec 2022, 12:57
I think this patch would do the same with less modules and with possibility to design IB and patch separately.
All the best
FP-30X programs.pat
(58.45 KiB) Downloaded 748 times
creal
Unread post by creal » 10 Dec 2022, 16:49
Hello Sylvain,
Thank you very much for the patch. It adresses my need in terms of IB design. The idea of "relative position" of an item from another is great. I even achieved to add titles upon each "column".
However, the patch does not work anymore because MSB, LSB and PC listboxes depends on the selected category. You removed all those listboxes excepted the ones of "String" category. And I don't know to reintroduce them in a smart way :(
EDIT : I tried to add 3 string text selectors (MSB, LSB, PC), as you did with preset names, but without any success.
EDIT BIS : I finally got it worked! (workspace attached). Maybe it can be optimized, I don't know, but it's already way better than the original patch.
FP-30X programs better.wkp
(197.88 KiB) Downloaded 434 times
Unread post by SylvainT » 11 Dec 2022, 08:27
You're right. Sorry I did the patch quickly and didn't see your MSB, LSB snd PC listbox were different.
Your patch is correct, you can simplify several things, and work on the organisation, to be more comprehensive. Use "thru" modules as I did. But this is personal.
(172.65 KiB) Downloaded 435 times
creal
Unread post by creal » 11 Dec 2022, 10:18
This is great to use the get string from comma module instead of the (no longer needed) listbox. Yes, the "thru" module makes things clearer. I will remember to use it for my next patches. Thank you, Sylvain.
Users browsing this forum: No registered users and 52 guests
