Inlet/outlet search within modules
creal
Unread post by creal » 06 Dec 2022, 13:59
One thing that would be cool is to have a search field for adding an inlet (or outlet) to a collapsed module. For example, I have a listbox that appears reduced with only four shown and used inlets/outlets (type, caption, reset, randomize). I want to add a knob to the "height" parameter. I am forced to unfold the listbox, scroll down, create a knob, fold the listbox, move the knob. It's even worse if I want to connect the "height" inlet to another module that is located above that listbox module.
Thanks for considering it,
creal.
Unread post by SylvainT » 07 Dec 2022, 06:24
Yes, you're right, this is a known issue. We are working on it, but it's not as easy as you can imagine.
Inlet/outlet on module are not all the same, some are direct access, other not. Tricky to explain.
creal
Unread post by creal » 07 Dec 2022, 09:43
Thanks for the reply, Sylvain.
