Currently, regardless of whether there is an alt-title on a module, you can only access it's primary value via its caption name in getObject(). In the case of controls that are dynamically named, i.e. by the vst parameter name associated with their value, you can only access them via the truncated/dashed version of that title.
This makes adding a meaningful access title useless, as the control's value still cannot be accessed via that title.
Need access to value of objects via alt-right-click title
Fixed in the Beta.
