Use of 'variant' with getObject
I've not seen the type 'variant' before. Is there a way to query what type it is?? How do I know whether to treat it as a string or a value?
- senso
the manual is not up to date on this point... sorry
use the function VarType(const V: Variant): TVarType;
Code: Select all
type TVarType = Word;
The variant types are described in the following table:
varEmpty The variant is Unassigned.
varNull The variant is Null.
varAny Represents a Variant that can hold any value.
varSmallint 16-bit signed integer (type Smallint in Delphi, short in C++).
varInteger 32-bit signed integer (type Integer in Delphi, int in C++).
varSingle Single-precision floating-point value (type Single in Delphi, float in C++).
varDouble Double-precision floating-point value (type double).
varCurrency Currency floating-point value (type Currency).
varDate Date and time value (type TDateTime).
varOleStr Reference to a dynamically allocated UNICODE string.
varDispatch Reference to an Automation object (an IDispatch interface pointer).
varError Operating system error code.
varBoolean 16-bit Boolean (type WordBool).
varVariant Indicates another variant.
varUnknown Reference to an unknown object (an IInterface or IUnknown interface pointer).
varShortInt 8-bit signed integer (type ShortInt in Delphi or signed char in C++).
varByte A Byte.
varWord Unsigned 16-bit value (Word).
varLongWord Unsigned 32-bit value (type LongWord in Delphi or unsigned long in C++).
varInt64 64-bit signed integer (Int64 in Delphi or __int64 in C++).
varStrArg COM-compatible string.
varString Reference to a dynamically allocated string (not COM-compatible).
varArray Indicates a Variant array.
varByRef Indicates that the variant contains a reference as opposed to a value.
varTypeMask Indicates the type of each array element.
type HResult = Integer;
// possible values of HRESULT
S_OK = 0 // No error. In some APIs, S_OK indicates a successful operation with a return value of True.
S_FALSE = $00000001 // No error, but the operation did not produce a useful result. In some APIs, S_FALSE indicates a successful operation with a return value of False.
E_NOINTERFACE = $80004002 // Interface not supported.
E_UNEXPECTED = $8000FFFF // Catastrophic failure.
E_NOTIMPL = $80004001 // Operation not implemented.
Type TVariantRelationship = (vrEqual, vrLessThan, vrGreaterThan, vrNotEqual);
function VarAsType(const V: Variant; aVarType: TVarType): Variant;
function VarIsByRef(const V: Variant): EvalBool;
function VarIsEmpty(const V: Variant): EvalBool;
function VarIsNull(const V: Variant): EvalBool;
function VarIsClear(const V: Variant): EvalBool;
function VarIsError(const V: Variant; out AResult: HRESULT): EvalBool;
function VarAsError(AResult: HRESULT): Variant;
function VarIsCustom(const V: Variant): EvalBool;
function VarIsOrdinal(const V: Variant): EvalBool;
function VarIsFloat(const V: Variant): EvalBool;
function VarIsNumeric(const V: Variant): EvalBool;
function VarIsStr(const V: Variant): EvalBool;
function VarIsArray(const A: Variant; AResolveByRef: EvalBool = True): EvalBool;
function VarToStr(const V: Variant): string;
function VarToStrDef(const V: Variant; ADefault: string): string;
function VarToWideStr(const V: Variant): WideString;
function VarToWideStrDef(const V: Variant; ADefault: WideString): WideString;
function VarToUnicodeStr(const V: Variant): UnicodeString;
function VarToUnicodeStrDef(const V: Variant; ADefault: UnicodeString): UnicodeString;
function VarToDateTime(const V: Variant): TDateTime;
function VarFromDateTime(DateTime: TDateTime): Variant;
function VarInRange(const AValue, AMin, AMax: Variant): EvalBool;
function VarEnsureRange(const AValue, AMin, AMax: Variant): Variant;
function VarSameValue(const A, B: Variant): EvalBool;
function VarCompareValue(const A, B: Variant): TVariantRelationship;
function VarTypeIsValidArrayType(aVarType: TVarType): EvalBool;
function VarTypeIsValidElementType(aVarType: TVarType): EvalBool;
function VarArrayCreate(Bounds: array of SizeInt; aVarType: TVarType): Variant;
function VarArrayOf(Values: array of Variant): Variant;
procedure VarArrayRedim(var A: Variant; HighBound: SizeInt);
function VarArrayAsPSafeArray(const A: Variant): Pointer;
procedure VarCopyNoInd(var Dest: Variant; const Source: Variant);
function VarArrayDimCount(const A: Variant): SizeInt;
function VarArrayLowBound(const A: Variant; Dim: SizeInt): SizeInt;
function VarArrayHighBound(const A: Variant; Dim: SizeInt): SizeInt;
function VarArrayLock(const A: Variant): Pointer;
procedure VarArrayUnlock(const A: Variant);
function VarArrayRef(const A: Variant): Variant;
function VarArrayGet(const A: Variant; Indices: array of Int32): Variant;
procedure VarArraySet(var A: Variant; const Value: Variant; Indices: array of Int32);
Can someone put that in a little more context? Like how to use it with getObject?
I tried this:
var st: string;
var v: TVarType;
v := getObject(address);
st := varType(varString);
that's not it. It gives an assignment error (which I would include here if it was possible to select text from the script compile log window.)
but of course it can't work, there's no reference to 'v'. But V is a const in the function, so I can't put a variable there either, can I?
I tried this:
st := VarToStr(v);
and it compiles, but I still don't get the string value out of it, just the number '83' as always. And it doesn't use varType.....
I tried this:
var st: string;
var v: TVarType;
I tried this:
st := VarToStr(v);
I actually don't need to query the variant for its type, I know it's a string. I just can't figure out how to get its string value.
Edit: It is actually a string value. It's just always equal to '83'.
Edit: I managed to get a different string okay, (YAY!) so there's something else going on....
I do not know what was going wrong. It suddenly started working. Maybe a space in a control name or something??? Anyway, all good now. No need for variants, just getting the string I wanted. suddenly. inexplicably.
- senso
you don't need to use variants explicitly:
Code: Select all
var S : string;
//PROCESS
PROCEDURE PROCESS();
BEGIN
S := GetObject ( 'patch.myfader' );
trace(S);
END;Olivier Sens
