I'm getting this messagge after downloading 5.2.221120 2.
Any idea?
iOS 10.14.6
Macbook Pro 13" 3,1 GHz Intel Core i5
8 GB 2133 MHz LPDDR3
thanks
“Usine MacOS-Intel 5.2.221120 2.app” can’t be opened because Apple cannot check it for malicious software.
The first time you launch Usine on Mac, don't use double click. Use right.click and select open.
will try
ok, it works, thank you
