HH5 Shutting Down
Ariajazz
HH5 Shutting Down
Latest beta version 5.2.221018 does no shut donw properly. Certainly it does it faster than previous versions of HH but an icon remains in the Windows task bar forcing to use the Window task manager to complety close it. In Windows task manager HH appears as "not responding". I have tested in three different machines with same behavior. Has anyone else experienced this?
QuentinRzk
- New member
I've the same issue since few days with this version. It's freezing randomly or I'm unable to shut down it proprely like you.
I'm using usine with Spat revolution (vst send and return) and I though it's freezing because of vst automation.
