Waves Plugins?
- Vincent
Because of latency, some Waves plugins don't fit for live use, but some actually do, and they do it good. Is there a possibility to run them in Usine? Did you try?
vincent michel
composer & novelist
composer & novelist
- senso
normally no problem you have to activate the 'deep vst scan' option in the setup.
Or better, I use an utility soft called 'shell2vst' you can find easily with google. It transforms wave shell vst's to 'normal' vst's.
- Vincent
Great!
Thanks Olivier.
Thanks Olivier.
vincent michel
composer & novelist
composer & novelist
