Load waorkspace in IB view
Ariajazz
Unread post by Ariajazz » 24 Sep 2022, 22:28
Hi all. My project loads workspaces that represent songs, Each workspace (containing several racks and patches) is a different song with its own settings and controls that are displayed in the IB view. When a workspace is loaded it does it fine but the RACK view is displayed instead of the IB one. Is there any way to make Usine stay or switch to IB view when a new workspace is loaded?
I've tried usin OnInit and send midi to Usine modules, but it seems to have a conflict with the key learn function (that I also need) so it does not work properly.
Unread post by SylvainT » 25 Sep 2022, 10:04
In Usine Setup, you have "Expert" tab. You'll find several startup options. Enable "Show Interface Builder". That's it.
But maybe you need at least a Pro Version for this tweak, not sure it is available on smaller version.
But you can also patch it with the Master Settings Module :
On Init - Logiciel Not - Pass If Changed - Master Settings (show IB)
Users browsing this forum: No registered users and 31 guests
