How to trig in fastscript… ?
Vincent
Unread post by Vincent » 17 Jun 2022, 11:35
Hi!
In a script, I'm wondering how to send a trig signal to a trig output:
Code: Select all
// trigger output
TrigNext := CreateParam('trig next',ptButton,pioOutput);
I suppose I should insert something like a "doevents" between "TrigNext.asInteger(1);" and "TrigNext.asInteger(0);", but I don't know how to code that.
Code: Select all
// something to insert here, but what?
I did not find a page with some infos on procedures and functions…
Thanks for the help.
Have a good day.
Vincent
vincent michel
composer & novelist
Unread post by sm_jamieson » 18 Jun 2022, 01:43
As I understand it, a "trigger" is when the output value goes to 1 for one processing bloc (possibly several blocks would be OK),
then back to 0.
The Process procedure is called once per processing bloc.
So you cannot do it in a single call to Process. You need to set the trigger output to 1 and also set a flag that will tell you to set
it back to 0 on the next call to Process.
This also implies you cannot have a trigger every bloc, you need 2 blocs to complete the trigger.
I'm not sure at what precise instant in the 1,0 sequence the trigger actually occurs.
Simon.
Unread post by senso » 19 Jun 2022, 09:31
yes it has to be handled by the Process procedure
Code: Select all
// flag
var sendTrigger:boolean;
Procedure Process;
begin
      if sendTrigger
      then begin
            sendTrigger := false;
      end
      else TrigNext.asInteger(0);
end;
Vincent
Unread post by Vincent » 30 Jun 2022, 22:05
Hi my friends,
Sorry for the delay: I did not recieve any alert... maybe a small bug in the forum...
Thanks anyway for your answers.
And yes of course, I understand now it has to be handled by the Process procedure!
Have a good day.
V
vincent michel
composer & novelist
