is it possible to extract CC numbers with array .
GenCode
Unread post by GenCode » 26 May 2022, 09:50
Its got to be possible but no luck yet . I'm trying to extract CC's assigned to various FL studio parameters and i think it should be possible with arrays but which one and how ? still trying but may be someone can nudge me to right direction i was hoping.
Unread post by rlgsbt » 26 May 2022, 12:33
try this : 2 arrays for code 1 and 2
CC values in array.pat
(43.28 KiB) Downloaded 560 times
GenCode
Unread post by GenCode » 26 May 2022, 14:29
Thanks . not working so far . will spend some more time later again .
i found actually another thing that is simpler and could work just right for what i need but can't sent cod 1, code 2 out . IN OUTPU DEVICE selection box i select IAC DRIVER BUS 1 . i'm on Mac so IAC is what i can use to communicate with FL but how do i connect IAC BUS to FL , through which module . i'm still very new to Usine so its noob question but take a look on a picture you might know how to work it.
Thx GC
