OSC Feedback
OSC Feedback
Unread post by grego mondo » 09 May 2022, 08:53
Hello I just bought a Stream Deck
I figured out how to dynamicly send from Usine to the stream deck
Column name, number and color, also elasped time.
Great tool for a remote for shows (always good to to have all information on a controller).
I would like to get feedback of the "on-off" state :
I ticked the "OSC feedback" box
I changed the "OSC feedback port"
but I got the message :
OBJECT:TMainFrom
PROC:ProcessOSCSendThread
ERROR:The requested IPVersion / Adress family is not supported.
I also tried to get the state "ON-OFF" from the "Master Settings" module and send it manually
but I guess when the engine is off it doesn't send 0 (as it's off it doesn't send anything).
But I remembered that the devices are always calculated so I just inserted in a device my Master Settings and OSC send and that works !
But I was wondering how does work the OSC Feedback and what is it's purpose.
Enjoy your day
Unread post by senso » 09 May 2022, 10:16
generally means that the network is not reachable. It's a WIN/MAC message.
check your target IP ?
Unread post by grego mondo » 09 May 2022, 10:25
What I try to understand is where would this feedback go ?
in my osc learn tab I see :
OSC message
OSC tag order
OSC mode
OSC feedback
OSC feedback port
but no IP destination for feedback.
What I am missing ?
