URGENT PB E010
raphaele dupire
URGENT PB E010
Unread post by raphaele dupire » 20 Apr 2022, 13:04
I don't change anything of my setup
but the soft says E010 error as a generic error or driver error please put it in the set up
I'm using now the basic driver of the computer. It's working with all my other soft..
I tried to restated the pc, change the driver in the set up..
many things but nothing new..
Could you help me ?
Je n'ai rien changé dans ma config de jeu et Usine ne reconnait plus aucun driver.
Mes autres soft n'ont pas de problème
Il m'annonce soit E010 erreur pilote de capture generique erreur
Soit E010 driver non trouvé
Soit E010 driver non connecté
J'ai redemarré l'ordi, charger d'autres projets.. toujours sans résultats
Pouvez vous m'aider ?
Merci d'avance
Unread post by senso » 28 Apr 2022, 11:31
I think that It's more a windows issue, generally a sample rate mismatch between inputs and outputs.
