Inlet to select module/plugin parameters in settings panel
It would be REALLY helpful to be able to adjust certain modules (especially audio effects) and non-GUI plugin settings without having to navigate through a patch to select it -- like the 'show editor' inlet, but just for bringing focus in the settings panel. This would make it MUCH easier to edit setting in complex presets without having to build interfaces for everything.
This would require settings for any modules with this feature to also be 'saved in preset'... (I just realized most are not
