HH5 v5.2.220218 does not mantain VST GUI position
Ariajazz
Unread post by Ariajazz » 24 Feb 2022, 22:11
Hello All. Previous version did it. Usine was able to keep the selected position of VSTs. Now when you open them they do it at a specific XY cordinates of the screen and not at the selected position. For me this is kind of an issue because with previous versions of HH I could open several VST GUIs each opening at its desired selected position, this way I could have several VS GUIs open in a organized way on the screen. Any way to tweek Usine and solve this?
Unread post by senso » 17 Mar 2022, 07:34
looks more as a bug report ?
We'll check
Ariajazz
Unread post by Ariajazz » 22 Mar 2022, 20:45
Any improvement on this?
Unread post by senso » 24 Mar 2022, 08:48
not realy.
You can try the following tweak:
replace the file /resources/devices/PluginWrapper.usr-win64 by the attached file?
PluginWrapper.zip
(1.13 MiB) Downloaded 484 times
Ariajazz
Unread post by Ariajazz » 25 Mar 2022, 21:37
Thanks Senso. So far the tweak seem to be working.
Users browsing this forum: No registered users and 160 guests
