HH5 processing Green Arrow.
Unread post by sm_jamieson » 31 Jan 2022, 11:25
In Usine when there is no correctly functioning audio interface (or select No Audio) then patches do not work correctly,
due to the main Processing thread not running I suppose.
Previous to HH5 it was impossible to enable the Green Arrow if the audio interface was not available, and if the Green Arrow
was enabled, patches would work correctly.
In HH5 if I have an unavailable audio interface in Settings and press the Arrow it changes from red to green so I think everything
is working correctly but patches do not work properly even though the arrow is green. This is very confusing.
Might be a bug I suppose.
But this part of Usine has always seemed a bit strange. Surely if the selected audio interface is not available, it should behave as if
No Audio was selected and calculated patches anyway.
Either way, it should not be possible to have a Green Arrow when the processing thread is not running and patches are not being
calculated.
Simon.
Unread post by rlgsbt » 31 Jan 2022, 16:54
I have the same problem each time I change the soundcard ! even if I know ithis issue, it takes me 5 minutes to figure out why my patches don't work.
I'm not sure the green or red color of the arrow is a good solution, but a pop up "the audio engine is not workking !" would be helpful.
Unread post by SylvainT » 31 Jan 2022, 21:50
Two inputs for your questions.
- when the audio engine is not running, the CPU consumption shown close to the green arrow is 0%. It insures you that your in trouble.
- in the module "setup settings", you'll find an outlet "audio engine running" you could connect to a switch and put it in the top header.
Users browsing this forum: No registered users and 120 guests
