preset manager bug ?
Unread post by sm_jamieson » 30 Jan 2022, 23:34
The preset manager "remove" trigger is not working correctly in HH5 (5.2.220122)
I have not tested in other Usine versions.
The preset that is deleted is sometime the number in "num store/remove", but sometimes item zero is deleted
and other times nothing is deleted. After the preset is changed it then starts deleting items again.
I also set the "num store/remove" to 1 and repeatedly pressed the remove trigger and it removed
item 1 which moved the items after 1 up the list as expected, but then removed item zero !
Then sometime it seems to be deleting the currently selected preset rather than the on in "num store/remove".
This was using the properties window to set the value, not wiring a value to the input pin, but
I don't expect that would make any difference.
Simon.
Unread post by SylvainT » 31 Jan 2022, 21:58
I can confirm.
The delete button is linked to current combobox and not to num store/remove.
Will certainely be corrected in next release.
Unread post by senso » 01 Feb 2022, 07:54
confirmed.
will be corrected.
