Usine Hollyhock 5.2.220106 update
Announcements
Unread post by senso » 06 Jan 2022, 19:53
5.2.220106 Major improvement
Apple-Silicon CPU compatible
-[usine] new engine more stable and faster
-[usine] full compatibility and optimization for MacOS Apple-Silicon
-[usine] new command in the inspector-panel to search strings and media file names
-[usine] new help hints on the modules in the patching window
-[module] all selectors and dispatchers, new option to set select in the range [0..N-1]
bugs
-[module] the audio-analysis-envelop-follower gain doesn't work
-[module] convolution and reverb generator, potential audio glitches
-[usine] grid command assignations are not saved properly
-[usine] direct-to-disk can record glitches when an object is not enabled
-[usine] most of reported bugs solved
Unread post by grego mondo » 07 Jan 2022, 10:01
x.iso
Unread post by x.iso » 08 Jan 2022, 03:41
