Hi, I quick question.
If I am only using Usine for audio at some point, do I save CPU by disabling the other types
e.g. start up options
-novideo
Usine starts without video engine and the setup-panel-tab-video is not visible.
-nolight
Usine starts without light engine and the setup-panel-tab-light is not visible.
Thanks.
Disabling video and light - save CPU ?
yes it saves CPU, but just a little bit...
