I'm trying to connect my Muse headband (cheap EEG) with a software called mindmonitor to Usine with OSC.
I get this error. I'm fairly new to OSC, but I don't get this error when monitoring the data on this computer in Ableton...
Any ideas?
Any help warmly appreciated!
Errors in receiving OSC
is it on the latest version of Usine ?
it seems that usine doesn't like the format of the OSC messages, Normally it's protected inside Usine.
I'm on 5.0.210726 apparently.
I'll try again with the latest update!
maybe the OSC message is not done properly from the sender or it sends multi format message (strings mixed with integer and float)
You could have a go with this to check the messages : https://hexler.net/protokol
