Lemur & Motionkit
Lemur & Motionkit
Unread post by gwennaelle » 15 Dec 2021, 17:34
I'd like use tactile interface (Lemur on Ipad) to control instruments from Motionkit (like boxplayers for example).
I don't know how to create the appropriate patch. I tried to copy onaother patch from Joffo for lemur but it doesn't work.
Would you know a tool, a tutorial or a model to help me ?
Thanks a lot
Gw
Unread post by rlgsbt » 15 Dec 2021, 19:37
To use Lemur with MotionKit patches, take the OSC messages and replace the busses X1 and Y1.
Here is an example using Box player. The "Multiball 1/x" come from the Lemur "Nexus 7 - studio combo" project. You also have to invert the Y datas.
Unread post by gwennaelle » 15 Dec 2021, 23:05
Thank you rlgsbt. It's a beginning but sorry I'm not familiar with Lemur and OSC and I need more informations.
On my Ipad I have the Ipad Studio Combo and on my computer I have Nexus but don't find the "Nexus 7 - studio combo" project.
So I created the object Multibal with its details x y z but then I don't know how have Multiball 1/x, ... Multiball 2/z. and neither do the rest...
What do I have to do ?
Thanks !
Unread post by rlgsbt » 16 Dec 2021, 07:34
I'm on android & PC. It should be another name for the Lemur project (have a look at the 5th page from "Studio Combo")
here are good tutorial to begin with Lemur : https://liine.net/en/downloads/lemur
and this one for OSC on Usine : https://www.youtube.com/watch?v=1PJGYNEN2j4&t=1s
