Hot Hand Usb
Hot Hand Usb
Unread post by gwennaelle » 03 Dec 2021, 19:41
I'm looking to play music with motion sensors
How can I use the Hot Hand Usb with Hot Hand Roll Pitch (in the add-ons) ?
Thanks a lot
Gwen
Unread post by senso » 04 Dec 2021, 08:21
The HotHand is a midi device so just put the patch on a rack with the HotHand device in the input of the rack.
The patch will create buses that you can see in the bind panel. You can bind any control : [shift+ctrl]+drop from the bind panel to the control.
Or simple use buses inside the patches.
Unread post by gwennaelle » 04 Dec 2021, 18:51
Hello Olivier
Super ! I don't have the bus reflex, a good progress for me ;-).
Thanks ! (It would be great if there were workshops / Usine)
