Loading specific VST-Plugin patches freeze Usine
Lioness
Unread post by Lioness » 03 Dec 2021, 13:28
My third question after the first few weeks that I have been using Usine:
I have some (only a few) VST plug-ins that show the following strange behavior: If I create a new patch with this plug-in, the plug-in window opens as expected and I can work with it without any problems.
If I then save the patch with the plugin and load the patch back into Usine at a later time, it freezes the application and I have to restart Usine. As mentioned, this only happens with a few plugins. Most of them contained in patches of the same structure can be reloaded without any problem.
The problem does not occur in other DAWs. There I can reload sessions, projects etc. in which the plugin was saved at any time and use the plugin.
"Playing is an activity that cannot be taken seriously enough." (Jacques-Yves Cousteau)
Unread post by senso » 04 Dec 2021, 08:16
one more time, can you joint an example?
Also, support@brainmodular.com is a good place to ask this kind of question?
Lioness
Unread post by Lioness » 05 Dec 2021, 13:22
ok, so here are attachments of one of the patches that freeze Usine on loading the patch, and although the logfile.log
