Is there a way to remove all the unused files located in the workspace folder, please?
I've made a lot of changes for a project and I need to reorder all the used files (and remove the unused ones).
creal.
Purge files function?
The best way is to make an export of the wkp with the media files.
Files which are not in the wkp will not be exported.
Users browsing this forum: No registered users and 111 guests
