Pad XY tactile issue
fdonato
Unread post by fdonato » 01 Oct 2021, 10:06
Since HH5, I experiment some troubles with XY Pad when using a tactile screen. Objects freeze or move only on one axis while other UI modules like faders or knobs are ok. And it is necessary to use the mouse in order to have the XY objects following the finger again during a short moment. Then it stops again etc... Any clue on that problem ?
Windows10 HH 5.0.210904.
Wifi on or off it the same, with or without an external audio interface.
François Donato
www.struzz.com
Unread post by SylvainT » 02 Oct 2021, 19:01
The problem is known and will be solved soon.
fdonato
Unread post by fdonato » 06 Oct 2021, 10:35
Thank you Sylvain
François Donato
www.struzz.com
Unread post by senso » 06 Oct 2021, 11:44
hi, this issue is solved in the next release.
fdonato
Unread post by fdonato » 06 Oct 2021, 18:56
Great! Thanks a lot Olivier.
François Donato
www.struzz.com
Unread post by rlgsbt » 16 Oct 2021, 10:56
Hi Senso, Sylvain,
The issue is not solved. You still have this probem with HH5.0.211012.
When you touch the screen for the first time, you chan increase the x values, but you cannot decrease them (no problem with Y axis). Then, you have to use your mouse to decrease the values and you can touch the screen again.
Unread post by senso » 16 Oct 2021, 14:42
not confirmed,
please use the bug report. This forum is not the good place to talk about this and we often need more precision...
