recommended way to store array data
I discovered the hard way that if I simply type values into an array get set module output, they are not remembered on restart. If I basically just want an array of constants, what is the most straightforward way to patch this? I'd rather not have a whole bunch of constant modules, but I could do that of course... Basically the value equivalent of a text panel?
If you want a fixed array you can use the math-constant and set values to 1;2;3;4; or whatever.
the semicolon ';' is the array elements separator.
Perfect, thanks!
