Or maybe a new way to do things?? Or the feature just moved somewhere else?
Load patch on startup.
--At least it's not where it used to be.
Array Editor
--is there any better way than editing output value using semicolons? Awkward for large arrays....
Don't show Poly number in caption
--Buttons and new faders always show it? I have always turned this off. still works with legacy faders.
Vertical text on vertical fader
--was looking forward to a vfader without left/top vals switched, but I always use Vtext. Again still working with legacy fader, so NBD.
Show MIDI in trace
--lots of workarounds for this so no big deal.
I guess I sure hope the legacy faders don't go away or change....
cheers!
-eric
Missing in V5, maybe?
found the hide/show poly order control under the view menu....
quick answer, of some questions.
Load patch at startup has moved to the new Expert Version with many other possible tweaking to create a stand alone version of the workspace.
Internally, the legacy-vertical -fader is a 'normal' fader with a rotation angle of 0.75.
