why can't I change these fader values?
Unread post by woodslanding » 30 Aug 2021, 03:09
As soon as I set poly on this fader bank, the faders stop working. I even copied the fader from another working fader, and as soon as I set poly it stopped working.
Maybe a bug, but maybe user error? This used to work fine under V4.
faderIssue.pat
(208.54 KiB) Downloaded 280 times
Unread post by woodslanding » 30 Aug 2021, 07:10
Interesting saga, but it's working now.
Suddenly, I saw the presets for normal faders (not legacy) show up in the view menu. So I took a snapshot of another similar fader, and applied it to the ones in this patch. Now they operate correctly.... so some odd fader conversion issue. I do notice that some of my faders are still 'legacy' and some are not. Not sure how the decision was made. And I was unable to get this look from the new faders before. I'll study the settings and see if I can figure why.
-e
Unread post by senso » 30 Aug 2021, 08:06
on the faders the setting 'fader:mouse active' is off.
The option 'edit enabled' disable all possible interaction, and the 'mouse active' disable the mouse interaction but the fader can still be modified with the wheel mouse and edition (double click)
Unread post by woodslanding » 31 Aug 2021, 22:53
Got it, thanks....
One more thing. Trying to get the caption to take up the whole bottom half of a horizontal fader. Is there a way to do this? Every setting seems to allow only part of the area to be used.... regardless of left right or center alignment, the caption never moves out of the lower right corner.
fader text.png (3.87 KiB) Viewed 4352 times
Unread post by woodslanding » 01 Sep 2021, 00:39
seems like this is an artifact of the v4 conversion. Started with a new fader, and it's fine.
Unread post by senso » 01 Sep 2021, 18:55
Not sure to understand, can you give an example of what you want?
Unread post by woodslanding » 15 Sep 2021, 08:19
Nothing, it all worked fine when I started with a new fader. The text runs all along the bottom now. I think in the conversion from V4 values for H and W got confused. Looks like the text is limited in width to the fader's height.
Users browsing this forum: No registered users and 41 guests
