Control Reset and Rescan MIDI devices from WKP?
Unread post by woodslanding » 16 Aug 2021, 21:26
It's probably a bad connection somewhere internally, but occasionally my KX8 controller seizes up in performance, usually after an especially loud large chord.
I used to think it required restarting Usine, but recently learned that a simple Reset MIDI Devices command will work. So I'd like to add that feature to my WKP panic button... Turning down the volume on my loud endlessly sustaining chord, opening up the side menu, selecting Options, selecting the MIDI page, and pressing the reset button from the touchscreen adds up to a lot of down time, (although far faster than restarting Usine!)
So hoping maybe this is possible....
cheers,
-e
Unread post by woodslanding » 16 Aug 2021, 21:30
Also, I often forget to plug in my pedal controller, or power up the Roli Seaboards (which do not turn on when they see power, unfortunately) and that requires a Rescan. Ironically, I am most likely to forget when I have a very short time to setup, i.e on poorly planned festival shows!
Would be nice to have that button in the WKP as well.
Unread post by senso » 17 Aug 2021, 19:06
the module usine-setup-settings has inlets for that.
