Current Object Orientation Taxonomy/Ontology
bermudagold
Unread post by bermudagold » 30 Jul 2021, 11:12
If I create a "section" and call it chorus....then later in my song/arrangement I want to repeat the chorus,...is there a container object that encompasses all the "grid elements" in a "section" and would allow me to simply insert a "chorus" object once defined?....or do I have to manually copy and paste all the "grid elements" (cells) in that "section" column over to the new "section"?
And even if I do the latter (manual copy and paste), does this merely create a new reference to the midi clips, audio clips, "racks" and "patches" represented by the "grid elements" in my new "section" ,...or does this create new objects that exist independently in my new "section" from those in the original section?....So if I change a rack or patch in the original chorus "section", will the changes automatically exist in any other chorus "section", or will I have to make the edit several times in every chorus "section"?
Unread post by SylvainT » 30 Jul 2021, 14:13
You can duplicate a section and move along the grid.
Select the section, clic duplicate on the left column. Then clic, drag and drop the section.
If you change a patch or rack you have put in the grid, it will desappeared from the grid.
Users browsing this forum: Bing [Bot] and 25 guests
