When I start up Usine I am getting a virus check warning:
www.sensomusic.org is infected with URL:Phishing
Is anyone else seeing this ?
Usine virus warning
- senso
It's a false positive alert. Usine hacks the system especially the network layer (to improve performances). Anti-viruses dont like that...
What is your anti-virus?
Hi Senso.
The antivirus is Avast Free version.
I thought it was finding a virus when Usine connects to the internet to sensomusic .org to check the license, or for updates etc,
since the antivirus seemed to block that connection. The antivirus found the same error if I connected to sensomusic.org outside
of Usine.
But it has stopped complaining now and the problem has gone away.
Simon.
of Usine.
Simon.
- senso
ok thanks for the info
Usine only check for updates and addons at startup.
