Draw in Usine
uge
Draw in Usine
Unread post by uge » 10 Jun 2021, 09:20
Hello again,
For a student work I'm doing I would to design some kind of drawable sonic panel (similar to penbox in motionkit).
Is there an "easy" way to build something similar in Usine?
Thanks a lot,
Uge
Unread post by rlgsbt » 10 Jun 2021, 13:47
Hi Uge,
you can open the penbox workspace in Usine to see how it works. Most of the MotionKIt workspaces are available with the addons or your can download the old version "MusineKit 2.31" to get it : https://www.brainmodular.com/motionkit/ ... -to-action
uge
Unread post by uge » 10 Jun 2021, 15:19
Nice tip! I'll check later, thanks a lot!
