Hello there,
I'm trying to connect a Quartz Composer interface to Usine using OSC.
I can receive data, but I can't to move parameters in Usine since the data seems in different format/value:
In this case I'm just trying to move a pitch parameter, but I've trying to convert the format in QC with no luck.
Any clue?
Thanks in advance
OSC Communication
try to use the data-scaling-change scale module to convert osc [0..1] into pitch [-24..24]
