I'd like to extract (short) file names of a list comma text and to get all of them in a list box. [extract file name] is doing the job but only for one single name.
I cannot use [comma text extract] because the paths will be different so the indexes will change. I' m sure there is a simple way ...
Thank you
list extract file name
in the listbox you have the option "hide path" and "hide extension" so you can connect the list directly without display their path.
Maybe it can do the trick?
This is the simpliest way...
Thank you very much!
