Usine log file (HH3)
Unread post by sm_jamieson » 23 May 2021, 14:43
Hi folks,
I am still on HH3.
I was playing live and between songs (luckily) and an error box popped up with a Midi Error and a "Please contact developer" message. I restarted Usine a quickly as possible so I lost the original LogUsine.log which might have told me what happened. And Usine does not put message in the Windows Event Log.
So the suggestion is that previous logs are stored when Usine starts up rather than overwriting the one there. I could create a startup script to do this I suppose. But perhaps logging could be improved so errors can be tracked down after they occur.
Thanks.
Unread post by senso » 25 May 2021, 08:28
it should be possible to do that.
