global remote file
franck
Unread post by franck » 11 Dec 2007, 12:02
Hello Olivier and usiners,
I have a problem with the dashboard ON/OFF remote. I would like to disable all remote (midi and keys) of this command. If I open global remote windows and clear all remote options to this command and save the new remote file modified, when I reload usine there is always remote control affects to dashboard ON/OFF ? If I open defaut remote file with wordpad and delete all remotes command dashboard ON/OFF, save it and reload usine with this new file modified it is the same thing ? I dont understand.
When I launch Usine I would like this buton is ON with no remote control.
What about my 2 posts:
first post in general discussion 03/12/2007
second post in suggestion 05/12/2007
Thanks Olivier
franck
Unread post by senso » 11 Dec 2007, 17:57
sorry I'm on the road, not so easy to find a web bar...
The basics remote commands like ON/OFF can't be affected to nothing. It's a protection.
If you want to disable such a command, make a stupid key learn like [shift+ctrl+alt+F12]
