Plugin controlling knobs
Ariajazz
Unread post by Ariajazz » 29 Apr 2021, 22:30
Hi all. I do have several Usine knobs that control different parameters of a plugin (Guitar Rig 5). Different presets are stored in GR5 preset manager sytem. The thing is that when these presets are recalled within GR5 the knobs in Usine stay in the last position they were, in other words, they don't move accordingly to the position of the preset recalled. Is there any way to make these knobs get the position of the preset recalled?
Unread post by senso » 30 Apr 2021, 11:05
maybe you can use the "pass if has changed" module as explained in https://www.brainmodular.com/manuals/hh ... se-plugins
Ariajazz
Unread post by Ariajazz » 02 May 2021, 15:07
Thank you very much for your help. I had to add another Pass if change module in between the know that goest to the plugin in order to work properly.
Users browsing this forum: No registered users and 25 guests
