Big Sur compatible?
oceanjaws
Big Sur compatible?
Unread post by oceanjaws » 09 Apr 2021, 21:28
Hi guys.
I've been trying to open Usine on my MB Pro, running Big Sur 11.2.3 but it isn't happening.
Are there any plans to get Big Sur compatibility?
Kindest regards,
Brian.
Unread post by senso » 10 Apr 2021, 11:10
hi,
Usine is compatible with BigSur !
did you try a right-click on the app + "open"
if not, open the /content of the package/Contents/MacOS/ and double click on "Usinemain" and please send a report at support@brainmodular.com with you logUsine.log file
oceanjaws
Unread post by oceanjaws » 10 Apr 2021, 12:16
I did try right click - open, and it asks if I want to reopen windows. I've tried clicking reopen and don't reopen, but same result. It gets to above 40% then fails.
I've opened package contents too, and opened 'usinemain' but same results.
I'll send a report to support.
Thanks for your help.
Great to know I don't have to change OS and it's something I can solve :)
Users browsing this forum: No registered users and 27 guests
