video recording quality
fdonato
Unread post by fdonato » 09 Apr 2021, 20:26
Hello, I'm a bit disappointed to get a poor 200 Kb/s video .avi file when recording with the video recorder module, whatever the value of the image rate or the dimensions. Can't find any setting to manage this. Does anyone know something about this limitation ? Thx
François Donato
www.struzz.com
Unread post by senso » 10 Apr 2021, 11:02
hello,
as explained in the manual https://www.brainmodular.com/manuals/hh ... o-recorder
The extension of the filename determines the codec used for compression. For best quality, use .mp4, .h264, .mov,.m4v if the codec is available on your computer.
senso++++
Users browsing this forum: No registered users and 64 guests
