Zynaptic type audio morphing
blugaruda
Unread post by blugaruda » 25 Mar 2021, 16:38
Hi All, I've just registered HH4 and I'm trying to get my head around it. I'd like to emulate the Zynaptic Morph https://www.zynaptiq.com/morph/ plugin. Has anyone here done this yet?
Unread post by senso » 26 Mar 2021, 07:20
hello,
It should be possible with FFT modules but the real question is the algorithm used by the VST. It's no so easy, probably few months of tweaking.
Take a look on the spectral examples in the tutorial, it will be a good starting point.
Unread post by SylvainT » 26 Mar 2021, 10:51
Zynaptic Morph looks like an interresting tool.
It could certainely be implemented with Usine modules, FFT probably as Senso said.
But I can ensure you that will be a very big deal. You'll need to understand deeply how it works, which algorithmes it uses. Then you'll need to implement those algorithmes in Usine and it will asked you a deep understanding of it patching capabilities. Simple FFT manipulations are easy, well explained in tutorials, but for complex manipulations you'll need to deal with cpu consumption and it's a hard trick. But not impossible.
All the best
blugaruda
Unread post by blugaruda » 28 Mar 2021, 23:02
Thanks Sylvain. I'm probably trying to run before I can walk.. Maybe when I get to know HH4 better, I can have a stab at it.. :-)
