Sidechain
Sidechain
Unread post by cmodica » 19 Mar 2021, 09:58
Is there a workarround to use the sidechain function of vst plugins ?
Or a workarround to patch a sidechain with a vst compressor or dynEq ?
Thank you
Unread post by senso » 19 Mar 2021, 19:54
The sidechain is often another audio input ?
so an audio bus can do the trick ?
Unread post by cmodica » 20 Mar 2021, 10:39
OK thank you.
I posted my question quickly without taking the time to search. We were in rehearsal and I needed to know if it was possible.
I'll look into it a bit, thanks for the info.
Unread post by cmodica » 22 Mar 2021, 10:32
Yes, audio bus do the trick. But it is important to remenber that side chain works only with VST3.
thank you.
