It's been a while and this particular project took a long while to hit the add-ons for HH4. Originally it's based on add-on patch that I've made for HH3 called Vidsynth and it included synthesis engine as well as internal modulation sources and matrix, which all in all made it pretty CPU intense.
For HH4 I wanted to optimize the patch as much as possible and only recently it struck me that I could simply separate whole Video to wavetable process in first place, then use arrays outputs to other modules for synthesis or any other uses that arrays may have (additive synthesis, anyone?).
So have fun with exploring what you can do with it! I even successfully fed the arrays into Bitwig's Grid via audio stream and was able to scan it perfectly according to samplerate/buffer size equation, so that's an option too!
if you have any question on how to use it, leave a message here or on Discord server. I'll probably share some examples of my experiments with it later.
Add-on: Video-to-Wavetable rack module
thanks!
it's fun
it's fun
Users browsing this forum: No registered users and 126 guests
